Judy S
Hello All I have a Culligan Iron clear system that has been a lot of trouble recently. To start with at least 3 times the Culligan tech has replaced the circuit board which temporarily fixed the error on the display. The last time he was out he left the installation guide... it says plainly it is never the circuit board but it will temp fix it. I went through the diagnostic steps to discover I needed a new seal pack which I replaced myself...fast forward several months and suddenly lost water pressure throughout house. bypassed system but did not resolve. Checked pressure in well tank and it was slightly off. Called a plumber and they found the bladder in the well tank was busted and replaced it but still no water pressure. They removed the Iron clear from the pipes and they were completely clogged up with media from the system. They got the pipes clear and kept the iron clear in bypass. I am not afraid to redo the resin but big question when reading earlier posts about this system the tank with the air pump is NOT supposed to have media? I ask because both my tanks have resin and the aeration tank was the source of fouling the pipes per the plumber. Am I better off just replacing with a more universal type system i.e. one that can have parts ordered and interchanged?
