keith23464
I posted this in the toilet forum but I wasn't sure if this might be the better place. It appears that more posts are done here. I have a two story house on a slab and in the past few months the two toilets upstairs both seem to have intermittent issues flushing. There doesn't seem to be any pattern to it. Occasionally you try to flush one and the water will spin and slowly drain but never go all the way out. If you let it fill again and try it again it usually works fine. It can happen even with just water in the bowl and happens to both toilets. These toilets are backed up to each other on a common wall in separate full bathrooms. I have gone on the roof and stuck a garden hose down the vent pipe and put water down it and that seemed to flow fine. The showers and sinks in those two bathrooms also seem to drain just fine. Any suggestions?
