yabadabadoo1026
So the tank on this bowl was wobly and I seemingly (maybe as a result) have a bad leak when flushing from the tank to bowl gasket. Tank said Kohler 4512 and the triangle bowl gasket to include in the one piece the 3 hole inserts that the bolts went thru. Picked the designated one up at HD . put on the tank and could not line up the 3 tank holes to the bowl holes, not even close. After a lot of cussing and insistence this was the wrong gasket kit or it cut wrong I calmed down to where I could think clearly and without the gasket set the tank on the bowl and even then couldn't get tank holes and bowl holes to align. This explains why the idiot before only attached it with 1 bolt and cut off 2 or the other legs of the triangle gasket and just plugged the other 2 holes in the tank.
I can only conclude the idiot replaced the original 3 hole tank maybe of another brand with the Kohler tank OR MORE LIKLEY mounted the bowl before affixing the tank. Only way to get the holes of this tank and bowl to align is to move and reposition the bowl out from the wall another inch or so. The tank needs to be setting back further from the bowl than it can now already against the wall.
I'm sure mounting a toilet at construction is not a big project but the issue now is the floor is tilled and I need to reposition that bowl. Never having installed one to know how the attachement of the bowl to the floor works can someone advise if that can be done without having to removed lots of tile. If it requires all that I might not be inclined to not do that which gets me back to some gasket and just attaching with 1 bolt again and plugging the other 2 tank holes and continue to have wobble. CAN NEW CLEAN HOLES BE DRILLED INTO A BOWL WITH SOME TYPE OF PROPER BIT OR THIS PORCELAIN IS NOT DRILLABLE?
Thoughts please, seems like what should be simple plumbing projects too often turn into a major headache.
Thanks all!!
Thanks all!!
