hello, i'm doing a remodel of an existing island vent. from the research and reading other island venting threads i read that you need a "flat patterned clean out tee" if you are going to install a garbage disposal unit.
i guess my questions is:
1) is picture C a "flat patterned clean out tee"?
2) if so, is that what i need to connect to the P trap on the drain side of the vent?
3) because originally i was going to use picture D as the sanitary tee and put an addition sanitary tee with clean out plug above it (see schematic B)
thanks!
dennis
thanks!
dennis
