Is this vented properly?
CatoMaior
New York
Hello all,
I'm adding a bathroom upstairs, and wanted to make sure this layout is vented properly. Thanks!
Horizontal before it reaches the flood lever of the fixture is an issue.
In a wet vent situation, the line to the lave, run with 2" could go horizontal and then pick up the lav and through the roof, because you could snake that section through the lav to keep it clear.
If your drawing had the 3" line run vertical, it would work. 45's are considered vertical, but not 90's.
CatoMaior
New York
Terry, thanks for your reply. I sure am glad I checked with you guys before I covered everything up. I've found a way to run the vent straight up from my 45 Y by furring out a nearby wall, thus eliminating the horizontal run on the 3" vent. I assume this would work?
Again, thanks a lot!
