sunnyday421
Here's the story: I hired a "GC" from my neighborhood to remodel my hall bathroom. He claimed to have remodeled many bathrooms in my neighborhood and that he does all of his own work and doesn't use subs. (My home was built in the late 60's and this bathroom hadn't been updated.) After an unpleasant 4 week remodeling experience that he said would only take 2 weeks, on Friday he said he was done and wanted to be paid in a hurry because he had somewhere to be. Although I'd learned that I don't like this person, I thought I could trust that he tested everything to be functional so I gave him the final payment. The next day, I start the process of cleaning and moving items back into my new bathroom. I discovered that the tub spout was kind of wobbly and that the water flow coming out was really low. In addition, the diverter valve knob wouldn't pull up so the shower didn't work at all. As a side note, the drain under the vanity sink was leaking and the hot and cold supply on the vanity sink were hooked up backwards on the faucet. I texted the contractor and he sent his sidekick to come over. He's a nice guy, but his command of English isn't very good, and in my observation, his remodeling skills aren't that good either so I had to explain the issue with gestures. He cut a hole out of the back of the shower in my closet and cut off the supply to the tub spout trying to diagnose the issue. He couldn't explain to me if he'd figured out what the issue was as he left. He basically said my GC would be there on Monday to figure it out. I took a picture of the plumbing. The shower valve is the Delta R10000. I bought the Delta Nicoli Tub shower kit from Amazon, which came with the cartridge and the shower valve. Can some one please tell me ALL of the things that you notice that may be wrong with this picture?
The GC returned today and replaced the plumbing to the tub spout with copper (so he says, as I didn't see it). The flow is improved, but it's still slower than I would've thought. I measured 1.8 gallons per minute. I measured 1.2 gallons per minute out of the shower head. The diverter valve also seems to work now. When I looked inside the spout after the sidekick left on Saturday, I could see that it was all white and gunky inside and that the diverter valve seemed really sticky with the gunk. I'm guessing it was pipe dope in there? I suspected that's what caused the diverter to not work and that he cleaned it out. The picture of the shower head pipe shows that it's not straight and the lever assembly above the tub spout is weirdly pointing down. Also the shower trim piece has been mishandled such that it's dented. Would you accept all of this as acceptable fixes? I'm not sure what to do at this point. I'm worried there might be a bigger failure ahead in the future but maybe I'm just catastrophizing.
