Is this PEX tubing water pipe installation proper practice?
Murphysf
SF Bay Area
Hi
In the crawlspace under my friends condo there are PEX tubing water pipes that are tapped into the existing copper runs. The tubing runs to a side wall and goes up between the wall at the foundation.
The lines go to a clothes washer that is that is in a utility room just above where the tubing goes up.
Is this an acceptable installation?
See attached photos
Thanks
Mostly acceptable. Sometimes when you crawling on your face on the dirt and it's 105 degrees you just kinda fling it however you can.
Really the pex should be supported every 32 inches with its own hangers and the pennatrations through the woods should be with some kind of buffer materials. But generally pex is pretty sloppy even when done properly. Sometimes making pex look good is so much work it's better to just buy copper.
Support is called for by all PEX mfrs. Touching wood is ok. Check the date on Uponor PEX to make sure it is not the stuff made 10 years ago because the red paint they used is well known to have a bad chemical effect but they won't pay claims 10 years on that old tube. Their new tube has a 25 year warranty.
Thanks I will check the date code, I assume it is printed on the tubing every few feet?
Thanks, also this just goes to the clothes washer, so not used for drinking or bathing, is the bad chemical effect still a concern?
The problem is leaking, rather than leaching chemicals.
I checked the date code and it is 130528 which is May 28 2013
Is there a concern? Should I call Uponor and ask the warranty department?
Where is the pipe INSULATION? Everyone forgets to insulate. Especially on an outside wall. Hot and cold need insulated. Unless you live where it is 70 degrees everyday LOL.
What about the steel flex lines touching copper? Wow!!!
