Andrwatln
Hello,
I recently had two brand new, identical, 50 gal electric water heaters installed in my house. Everything seems to be working properly, but the way the pipes are setup looks wrong to me. Can anyone confirm?
From what I've read, everything about the two heaters needs to be identical, including the length and size of the cold pipes running in and the hot pipes running out, the fittings, etc. Here is a correct configuration from waterheatertimer.org.
The way my heaters were installed resembles that of the cold water line in this diagram, except that my hot water line is installed the same way that the cold is shown below.
From what I've read, it's critical that both the cold and hot water lines meet at a midpoint like the first two diagrams, and then you must have equal lengths of pipe from the midpoint to the first fitting, and then the same length of pipe again to the water heater.
Can anyone confirm whether or not my system is configured correctly to have equal draw from both heaters? Photos of my setup are attached.
