Plumbing from the well comes in via PVC, then gets to the valve that sends water to the pressure tank. That short piece is copper and developed a pinhole leak. It's underneath the bottom of the tank so was really hard to work on. I got a small section of hose and a hose clamp for a temporary fix, but as I was tightening the clamp the pipe shattered. We had iron problems in the past, but I didn't think the pipe would be that soft.
I cut the pipe off and put a sharkbite cap on it for now. I wasn't sure how to get the pipe disconnected on the bottom of the tank and didn't want to make it worse. When I turn the well pump power back on, the valve sounds like it's turning on and off over and over and there is some serious water hammering. I'm sure it's trying to figure out the pressure in the tank which is no longer connected.
Long story short, is there any way to get water flowing to the house until I can get a plumber out here? Of course it was Sunday afternoon when all this happened. Thanks for the help!
