Repiping a house and some joints are in tight areas. Even though I will make rough guess 1/2" or 3/4" mark on the pipe doing a lot of joints it is very time consuming to accurate mark for every joint and after doing a lot of joints you forget to mark. Some joints don't push in easy and hard to tell after it is glued did it really bottom out or not.
So I there trick plumbers use to:
1) Mark there pipes or know that the joint properly bottomed out and
2) and good method to know you did not accidentally forget to glue up a joint such as putting a check mark after you glue up each fitting.
