Is there a PVC epoxy or similar product to fit a broken flange?
CountryBumkin
Active Member
Orlando, FL
I have an inground pool with two waterfalls. One of them has a broken flange where the 1-1/2" PVC fitting attaches. The flange is part of the fixture but has cracked at the top (probably due to weight/pressure from settling paver deck above.
Replacing the waterfall fixture is not an option.
Is there a product I could use to repair the flange? Maybe an epoxy?
If it's a hub fitting you are going into and you need to remove the pipe glued inside, that might be able to be drilled out, sometimes with a stacking hole saw set up. The small bit on the inside to center it, and the outer bit to cut the pipe out.
How far back is the flange broken?
CountryBumkin
Active Member
Orlando, FL
It is broken flush with the back of the waterfall housing. The flange is cracked at the top (about 9 o'clock to 3 o'clock).
I can drill out the 1-1/2 pipe, but that still leaves the repair of the flange.
EDIT: when I say "flange" I am referring to the short section of the waterfall fixture that the pipe fits into. The flange is not a separate item - it is part of the waterfall fixture. I believe "flange" may have a different meaning from I'm using, in the plumbing business.
I'll post a photo of this when I get home.
Did you glue 1.5 inch pvc pipe right into that short section of the waterfall fixture?
If you remove the pipe with a Rambit, I would make sure the pipe I glued in there next time was not DWV pipe. You might even go with schedule 80 PVC.
Another possibility is to patch with a 1-1/2" Schedule 40 PVC Pipe Inside Connector
That would glue into the inside of a schedule 40 pvc pipe.
CountryBumkin
Active Member
Orlando, FL
Here are a e a couple of photos taken during construction that show the Waterfall fixture, and one taken today showing the crack location.
The problem is that the pvc pipe (mine has a 45 degree coming off. Coming off the 45 is flexible PVC spa hose) goes into the flange (nipple - whatever the correct term is) on the waterfall fixture - and it is that flange that is cracked. So if I remove all the old PVC piping, I still need a way to repair the crack on the top of flange. This flange is not removable - it's part of the fixture.
That blue part/thing in the photo of the Waterfall is just a cap that fit over the flange while the waterfall is put in place, then removed for the PVC pipe connection.
I hope I am being clear.
Thanks for all your advice.
CountryBumkin
Active Member
Orlando, FL
That inside connector might be the fix. I do have a Rambit
CountryBumkin
Active Member
Orlando, FL
I spent some time this evening disassembling the fittings. The broken part is not slip fit - it is a "face to face" connection. Glued at the factory. I removed the old PVC spa hose from the 45 fitting.
So what materiel would be best to glue the flange back onto the face of the Waterfall fixture?
I would think the Oasis people would have a good suggestion for the glue. I would be thinking an epoxy initially.
CountryBumkin
Active Member
Orlando, FL
Call Oasis - why didn't I think if that? Good idea. If they can't/won't help - then I'll try epoxy.
Thanks
If the material is actually pvc, pvc cement should work. PVC cement literally causes the plastic to melt, and when the solvent evaporates, the parts become one. Can't tell how dirty the flange of that part is, but that would have to be cleaned off. The PVC cleaner MIGHT work, but can't tell exactly what's on there. The PVC cement has some dissolved plastic in it that helps to fill small voids, while the solvent softens both pieces, so their surfaces can flow together.
