Is there a push in 1/2“x3/8” MNPT coupling?
You could use compression such as Brasscraft 68-10-6X.
You may be able to use a valve with a
https://aquamedix.net/welcome-to-my-thread-talks-3-npt-vs-npsm/
You could solder on an adapter.
https://www.homedepot.com/p/SharkBi...ee-Dishwasher-Elbow-Fitting-U281LFA/202830513 is right-angle.
Mini Me
Toronto
I am trying to avoid any aditional work like soldering or threading as I do not want to have any issues with a leak cause by my lack of experience
If there is a 1/2" x 3/8" adapter that can be soldered I can try to do that upfront before installing the stub out but I would rather use a push it fitting if I can since it will not be behind the wall and it would be fool proof :))
Compression does not involve soldering or threading. It does require two wrenches, and if those wrenches are short, it requires strength. A bit of plumbing grease or pipe dope on the threads before tightening will reduce the torque needed.
I think most novices under-tighten, fearing they will crush the pipe. If you get a small leak, give the nut another 1/8 turn or so.
That Sharkbite U281LFA would work very well for you. Don't orient the threads upward, but rather to the side. Then the right angle from above connects nicely.
Mini Me
Toronto
Hmmm
One of the reviewers is saying it won't accept my 3/8" shower hose
Reviewed in the United States on February 21, 2016
Verified Purchase
The only MAJOR issue with this elbow is it stated "dishwasher" which I assume it would accept compression 3/8" fitting but it does not! It is a standard 3/8" nipple fitting. I looked for specs. but didn't see anything about fitting. Don't buy if you have a compression flex line as this will NOT fit.
3/8 compression uses a finer thread (24 TPI) than 3/8 MNPT (18 TPI).
wwhitney
Berkeley, CA
3/8" compression threads and 3/8" MPT are two different things. Which one does your shower column have?
Cheers, Wayne
Mini Me
Toronto
It is a regular hose, see the manual and the pictures above so I am assuming the guy is right I did not know this detail.
So the idea to use an elbow is excellent but now I need to find the part that takes a 3/8 hose for a shower
Here is a picture of what I have
Mini Me
Toronto
I guess at this point (learned more in the mean time about the various fittings and how they work) I could also use a compression fitting to transition from copper to 3/8 so the elbow end toward the copper stub out could be either 3/8 push in or 3/8 compression, right ? All I am trying to do here is to avoid soldering which I might not get it right
It has 3/8" hoses that connect to a 3/8" MPT connectors
Was there something that actually said that? If so, don't lose sight of that. If not, well... dang, this has been weird.
Next you may be saying you find out that you need to connect to some metric thread.
Mini Me
Toronto
Nope just my own ignorance. I did not know that the NPT thread is not the same with the compression thread
wwhitney
Berkeley, CA
I don't have a 3/8" compression nut handy to measure, but I'm pretty sure that they are smaller than 1" across. Therefore your photo likely shows a connection for 3/8" MPT.
Cheers, Wayne
wwhitney
Berkeley, CA
They use 9/16 UNEF thread which is 24 tpi.
Whereas 3/8" NPT threads are 18 tpi, so one approach to differentiate is to count the thread density in the nut.
I found a 3/8" compression end supply line, and its nut is 5/8" across the flats, and a bit over 11/16" across the points. So the picture is surely 3/8" NPT, and the elbow you found should work. The commenter's difficulty in the review was not understanding the difference between NPT and compression threads.
Cheers, Wayne
Mini Me
Toronto
I called the store and the said it is a 18mm thread.
Here is a picture of the thread and of the plastic cap that came with it
