Daniel F Murphy
Hello,
We've been having years of water softener problems. At one point the system worked and the water was clean and drinkable. Now it's extremely metallic in taste and smell. Recently we had professionals install a new head and new media in the neutralizer tank, and they also "cleaned" the head on the softener tank. We also replaced the 15 year-old softener media. All to no avail.
A couple weeks ago I decided to install a sediment filter before the neutralizer and softener, which produced some troubling findings. After only 2-3 days the filter housing was completely clouded with rusty water. I replaced the filter and a couple days later it looked just as bad again (picture attached).
My question is this. Do we have a bigger problem than a standard softener setup can handle? Should there be this much "rust" in the water coming from the well? Do we even have the correct equipment to handle this?
My next step was going to be to either replace the piston in the softener head or replace the valve altogether. Thank you in advance for your help.
