Bluegrass Picker
Hi,
I am going to be installing a toilet in our bathroom remodel / retrofit.
This previous thread: https://terrylove.com/forums/index....ax-ring-on-a-toilet-with-a-offset-flange.651/ discussed a wax ring sealing problem with the offset flange, and I didn't quite understand the situation and why it required a "fix".
Question: If I use an offset flange (Sioux Chief ABS) will I encounter problems such as in the other thread? If so, how do I avoid problems with the fitting, or should I just try to use it only as an absolute last resort?
I guess the bottom line is: Will a toilet with a standard wax ring seal correctly with an offset flange?
Thanks so much in advance for the help, and Happy Thanksgiving to all.
Bluegrass Picker
Bluegrass Picker
