Hello,
First let me say I appreciate all of the informative posts, you all have saved me a lot of time, trial and error.
Some back story to my current issue. About 10 years ago my well developed a leak right at the pitless adapter. It was threaded PVC and one of the threads cracked so the pressure tank wouldn't hold pressure. I pulled that out and dropped in a new pump on black poly 1" pipe. Pump is about 135' deep and sits in 10 or 15 feet of water.
Recently the pump breaker started tripping and I discovered my pressure tank bladder was low so I charged it up and life went on. Then the breaker started tripping more often, so I replaced the breaker thinking it may have gotten weak from all of the short cycling. At that point I realized the pressure switch wasn't cutting out at 50 psi. And if I flipped the breaker off, the water would sometimes, but aggravatingly not every time so I couldn't point clearly at the check valve failing. I replaced the pressure switch and the cut in and cut out started working as it should, however at that point every time it cut out, it would drain, so I decided to pull the pump.
I pull the pump and it is coated with thick chunky rust starting at about 15' from the pump. The pump itself had a ridiculous amount of this rust detritus collected about it.
Every time the breaker had tripped or pump cut out where the water drained back down, upon reenergizing the pump, I got a ridiculous amount of black dirt stuff in the first few gallons. Enough the plug up any aerators or screens in fixtures and once even clogging my 5 micron whole house filter that was a day old. 10 years ago I remember getting some black detritus in the same conditions but not nearly this much. I figured the bottom of the well was being agitated every time it backflowed down.
Anyway, got the pump out. The stainless barbed fitting at the pump was corroded through and I thought that must be the problem, either the gap was the leak, or junk was keeping the check valve from closing or both. Got a new pump, brass fittings this time, as well as a brass spring loaded check valve which I installed directly above the pump check valve. I simply don't trust the free floating check valve on the pump but trying to heed all the advice here about using a single valve only I figured that close proximity wasn't going to cause any hammering.
As I get the torque arrestor adjusted and start dropping it back down I was preparing to fight with the pitless adapter and sneaking the arrestor by. Except it went right by without a hitch. Which didn't seem right so I brought it back up and out.
Yep, the pitless adapter is gone. I never heard it splash at the bottom but somewhere in the process of pulling and dropping back down, it broke off.
When I first bought the house 15 years ago the well was in a pit. DNR made us bring it up to code which meant bringing in a well guy and welding another 8' of casing to get above grade. I'm trying to remember exactly what it looks like down there where the adapter is as far as pipe but can't exactly. I want to say it's black poly with a barbed fitting just like on the pump. So my working theory right now is that fitting rotted through and either that was leaking or it was leaking there and at the pump.
Either way I'm screwed. The only fix is digging down there and putting a new adapter on. That wouldn't be so bad if I could get at it with a mini ex, but my well is 6' from my house and under my deck...
So before I tear the deck apart and hand dig a pit, I was hoping to get an opinion on the rust. Do you think the casing rotted through somewhere? I've had this thing out 2 other times and never seen anything like this. Is my old adapter sitting at the bottom a concern?
Or do I need a new well?
