I like to try to drain a couple of gallons or more from my water heater every 6 months to a year to see how clear or dirty the water is. I shut the water off at the shut-off where the line enters the house because the last time I used the shut-off valve at the water heater, it would just turn and turn and had a slight leak on it. Tightened the nut on it and stopped the leak, so I am hesitant to use it. It is a gate valve.
After shutting water off, connected hose to drain on water heater, opened up the drain, could hear some gurgling, but no water came out. Realized I hadn't turned a faucet on, so turned the kitchen faucet on, but still no water from the drain. Opened up the pressure relief valve, and still no water. Turned faucet off, closed pressure relief valve and turned water back on. Opened up drain and of course water comes out. The water was pretty clear, a little cloudy from the the heat. I drained a good 2 gallons that way, then turned the water off again and tried, and still couldn't get any water out of drain even opening and closing PRV.
Wondering if I have a very bad clog, too much sediment buildup in bottom of tank? I thought opening the drain with the water on would help to clear and dislodge any clogs. What would be the best way to figure out what is going on and remedy it? It is a 38 gal. electric and it is just over 3 years old.
