Had to install new innards of my toilet water tank because the old one kept running water.
The tank wobbles as i put the seat cover up. Checked my bolts and one side isn't fully screwed in. But problem is, I have to screw the nut from inside the toilet tank because the bottom side is in a nook. Had the toilet tank with water yesterday and today and no evident leaks around toilet.
Checked on here to see that alot of others have similar problems. Saw a couple posts indicating that some toilet tanks wobble.
My girlfriend and I do not tend to lean on the back of the tank anyway, so should we care to tighten the nut on the one side?
If I must tighten, how do you figure i get to tighten the nut from the underside given the nook that it is in? (Used a 13mm wrench to hold the nut in place while I used a flat head screwdriver to turn the bolt from the top side, was a pain to do this when taking off old bolt and was a pain to do so when putting on new bolt).
My toilet is an Aquadis and the tank is two bolts.
Pictures:
Pictures:
