Always been dumb with wells and plumbing, so when my system was installed I requested everything on the "bigger is better" theory! Now, Im learning a little, and have some questions. Im very anal on my home, and anything to do with it...dont care if I have to sell off myself to pay the bill. Lol! So, a recent well inspection and test, I was told that I have too much pump, and it is running off the curve. Details...well is somewhere around 220-240 deep (have to look at records to give you an exact) static level at drilling is 65 feet, average static pumping level under normal to moderate useage is 120 feet (yep, I do remember this much...part of the tests each year). Pump is a goulds 10ej10422 10 gpm, 2 wire 1 horse. NOTE...THE WELL SERVES TWO OTHER HOMES BESIDES MINE (no written agreements, they are all family, so someday the well will be for me only)!!! I was told that this pump is actually pumping at between 14 to 15 gpm, measured at a hydrant beside the well after a 30 minute free flow to drain the tanks and lines, and that this is too much pump. Was told that the pump runs under too low of a head most of the time, and that I either need a smaller pump, or a throttle valve. I do understand head, BUT I always thought that the less resistance, the lighter the load on the pump, and the less the pump works, the longer it will last~!!!! Here's the confusing part...if the pump is really oversized, then is that really such a bad thing? This pump is 14+ years old, and by estimates in my mind, has 42 years of "normal" single household duty on it pumping for 3 full houses over the last 14 years! I had posted earlier about a pressure tank/line failure which has taxed the system since december of last year, and we are saving for a replacement pump, cable, and drop pipe, and more than likely will include a cycle stop valve. Should I put the same size pump back? OR...if you were installing this system today, and thought the current pump to be too large, what would you install? Thanks guys!
