When they built the house, they dropped the drain right in the middle of a floor joist. They cut out a notch in the joist, but didn't leave enough room, and the copper has developed a leak presumably from decades of rubbing against the wood.
It's on the end of the drain line, so I figure the easiest thing to do is just cut off the end of the main drain line, and run PVC all the way up to the sink. It looks like they used a sanitary tee, but from what I've read, it seems that a wye should be used for a vertical to horizontal transition. Does the diagram I have here look acceptable?
I will ensure that the PVC is not in contact with the joist, by widening the existing notch a bit. We are in a rural area, and code/inspections aren't really (much of) a thing here... mostly looking for input to save multiple trips to the hardware store, hah. Thanks for any input!
