Is my Navien set up correctly/ & circulating too often?
Barry Weaver
Cleveland Tn
We have just built a new home about six months ago. We had a Navien on demand water heater installed. I am concerned if the unit was installed correctly. I have found loose gas fittings and a few leaks since the install. It just makes me second-guess the installers ability. I have a picture of the dip switches. It also seems like it circulates very often. Is it common with these? It does have an internal circulation. It’s on propane and I checked to make sure the propane conversion was done& it is. Thanks
Breplum
Licensed plumbing contractor
San Francisco Bay Area
The icon for faucet spray shows that "recirculation" is set.
Dip switch 2 is on, so that confirms it.
I must note that the condensate drain line appears to be 1/2", which is contrary to recommended sizing in PEX because the i.d. is smaller that PVC , and check the fittings, they must not be metal fittings because the condensate is acidic. Plastic fittings are ok.
With recirc on, it will exercise every 1/2 hour (at least that is what I think the interval is) to check the hot line temperature. One terrific option is to install the Navien Hot Button (On Demand Control) module and then daisy chain push button call for recirc in any room where you want. It is low voltage and makes a lot more sense than always keeping pipes hot.
BTW, all hot piping throughout the house should be insulated with 3/4" wall insulation.
Not good: Having tight elbows on the hot water supply line does not contribute to good flow. We normally want to minimize tight elbows because constant recirculation caused erosion.
FYI, the recirculation "Pump Exercise Operation Interval" is in the set-up Parameters P.13, it sets the circulator idle sit time before activating the pump exercise feature.
Barry Weaver
Cleveland Tn
Thanks breplum so, may I ask this. I looked and the pipe is not insulated but it is in a spray foam wall encapsulated crawl space. Would it make sense to try and insulate it now? Also in my Navien operations manual calls p.13 “pump fix protect period time” or is it p.04 “pump exercise operation time”. Will one of those functions slow this very often circulation down? It’s weird, it’s 90 degrees outside and I hear this unit running a lot. I just don’t want to throw $ away.
Would the hot button eliminate most of the issues of non insulated and running a lot? Thanks for your information Sir!
Breplum
Last two questions, answer is 'Yes'. Recirc would not run, unless you pushed the hot button (s), you can add quite a few button locations. And you could opt to not invest in insulation if you only ran with a hot button. Better to insulate, though.
p.04 “pump exercise operation time” is just as described, not very relevant and factory setting is usually fine.
The built in aquastat will always shut off the recirc pump when it is back up to temp (what we call: aquastat is 'satisfied')
If the crawl space is accessible, the hot water pipes are supposed to be and should be insulated. It is incomprehensible to any educated person as to why it was not.
Andrew Herman
Greensboro, NC
Can I ask an add on question?? I just replaced an 11 year old NR-240A with a new NPE-240A2. Old unit had leaks in several areas and was more practical to replace. On the old unit - it had been set to circulate 24/7 and had been running constantly for 11 years with no issues till now. Hot water loop between floors is probably 200+ feet.
With the new 240A2 - I noticed a larger water temp drift from the far faucets - above you mention that the pump exercise and temp checking is only every 30 min. Is this the same as my old unit?
I could change the installer settings, but curious before I do.
Thanks,
Andrew
Plumber69
Prince Rupert, British Columbia
That is a really bad install. The metal fittings on the condensate will be leaking in under a year. The condensate will eat right thru them in no time. I'm curious how the venting was done inside and outside. By chance did fader industry install this
