Is it possible to connect a washing machine to a Liberty pump?
SD-777
NJ
I have a setup with a Liberty 404 pumping the water from a basement sink next to my laundry. The washing machine directly pumps into the sink itself. The issue is that this can get smelly and I was wondering if I could tie the laundry discharge directly to the Liberty pump? I would be putting in a trap between the washing machine and pump, as well as a check valve on the laundry discharge.
Included: Picture of the current setup and my proposed laundry coming in. I'm assuming using a double sanitary tee is the better method because the travel is horizontal? Would this setup work and not cause any issues?
currently you have 2 inlets to the pump basin one on top for the sink. whats the other one for? appears to not have fall?
Im not in favor of your tee as planed .
I think it probebly needs a vent not a AAV
I think it probably needs a vent not an AAV
https://s3.amazonaws.com/s3.supplyhouse.com/product_files/Liberty-Pumps-404-Install-Instructions.pdf page 5 says "Do not use one-way quick-vents or air admittance valves". But oddly, the instructions say
Provision is made for a vent stack to allow extra volume for high
suds conditions, and to ensure proper drainage of the fixture. The
vent pipe should have a union to facilitate removal, if required,
and shall be connected directly to a building or house vent
That seems to say that a vent is optional, but a washing machine would be a high suds thing I think.
Breplum
Licensed plumbing contractor
San Francisco Bay Area
WM is not compatible with mini-pump basin like this. To use that pump with WM you must use a deep utility sink(aka laundry tray) to accommodate the potential capacity limitation of the pump and basin.
SD-777
NJ
There is only one inlet from the sink. The other 2 are vent out and discharge.
SD-777
NJ
SD-777
NJ
SD-777
NJ
So the issue is that the Liberty's basin is just too small for the WM? Would it be that bad if the WM discharge backed up a little bit into the sink until the pump could catch up?
Edit: In particular after reading in the manual "Provision is made for a vent stack to allow extra volume for high
." Seems like it's made for this type of scenario?
