Currently my sump discharge on the exterior of my house is routed through 25' of ABS down a slope to eventually discharge to the sidewalk in front of my property. There is no drain cut at the sidewalk due to it being irregularly shaped (and county owns it not me).
They are re-doing the sidewalk and have cut a drain on the opposite side of the corner. The only way I can connect the sump to this drain and still be able to use the gate on the corner of my property is to bury a section of discharge tube below the height of the drain.
If I do this will the sump still clear the line when it needs to run? I suppose there is also the realistic possibility that water draining down along the street will back up into this channel and back the system up.
Frustrating situation so I am probably stuck with what I'm already doing, but this will hasten the demise of the freshly poured sidewalk and the discharge tube running down along the corner of my property is also a bit of an eyesore.
Thanks.
Thanks.
