duuuuuude
Hi Everyone,
Hoping to see if I can get some confirmation to see if my thinking about a new tub spout is ok.
I currently have a Kohler screw on tub spout that attaches with a 3/4" brass nipple.
Wife wants a more decorative spout that is 1/2" slip on and the spout says slip on over 1/2" copper wire.
I'm assuming the 3/4" brass nipple is screwed directly into the L-joint behind the wall.
I understand how screw-on and slip-on tub spouts work and know how to install. My problem is that I've never sweated on a threaded end on a copper wire, nor do I have the tools. This is a one time project so I'd rather not buy new tools/materials for this because I think I can get away with soldering altogether.
So, my question is this. Can I use a 3/4' to 1/2" bushing attached to a 1/2" brass nipple to get the piping to the proper 1/2", then cut off the 1/2" nipple's threads to make the exposed stub non-threaded (and the correct length), and slip the new spout over the brass pipe as though it was a copper pipe?
Is there a problem with of material combination if I were to use a brass nipple with a slip on spout instead of copper? I can't find anything definitive about the piping material other than seeing the standard copper for slip-on spouts or brass nipples for threaded tub spouts.
Any insight would be appreciated.
Thanks so much!
Thanks so much!
