Is it ok to blow air through pump?
Discussion in 'Tankless Water Heater Forum' started by Paleomedia, Jan 26, 2019.
  1. Paleomedia
    Paleomedia New Member
    Jul 26, 2010
    Boise, ID
    Hi -- I need to pressure up my radiant heat loops to 100 psi for an inspection... is it ok to blow air through the pumps with a compressor? I have two Grundfos ups15-35sfc pumps with check valves in and don't want to damage them.
    Will the check valves and one way valves all hold 100 psi air?
    Thanks,
    Nate
  2. jadnashua
    That amount of pressure seems way excessive. You'd need to isolate the boiler before you tried that, or you might damage some things. If it was left in the system, you'd need to remove the pressure relief valve or plug the outlet, or you'd never get it above that release point, typically 30psi. If it was a potable water system, that might be a useful test.
    The bearings in those pumps typically are lubricated by the water...not sure how well they'd last with air spinning them. Now, it wouldn't be for all that long...just don't know. A call to the manufacturer of the pump might be worthwhile.
Similar Threads: blow through
Tankless Water Heater Forum Navien exhaust vent screen blowing off - explosion in vent pipe? Aug 16, 2019
Tankless Water Heater Forum Takagai TM-1 blows fuse on circuit board Apr 11, 2012
Tankless Water Heater Forum Water Heater About to Blow - Need advice! Oct 25, 2007
Tankless Water Heater Forum Water flowing through tankless heater at beginning and end of cold water draws Nov 20, 2014
