Is a Liner for Copper Pipe Hangers Necessary?
WorldPeace
Livingston, New Jersey
I am installing a copper manifold for my home water supply. I'm going to use these copper bell hanger straps to fix the copper manifold to plywood. But, I notice that they don't include a liner. But, I've also seen pipe restraints that are sold with liners like here.
I am wondering why the copper pipe hangers I see for sale don't include a liner. Since pressurized pipes constantly move around, wouldn't the friction between the pipe hanger and the pipe eventually wear down the pipe?
Is there a pipe liner that you can buy separately, which is made of neoprene, silicone, or Teflon?
You make a good point.
Just an idea: Maybe go up in size on the bell hanger, and use sliced segments of PEX. 3/4 PEX is about 0.681 ID, and 1/2 inch copper is 0.625 OD. Maybe rip the pex on a table saw where the kerf cuts a segment out.
Or maybe use some 5/8 ID vinyl tubing (over 1/2 inch copper) to make the little cushions/insulators.
Those bell hanger are copper plated steel.
Tuttles Revenge
We're pulling apart a lot of work from the early days of copper installations where J-Nails were the norm. They were generally copper coated steal and sharp edged. They did cause a lot of squeaking/creaking noises, but I doubt I've seen one wear through a tube. The bell hangers you've linked look like they provide a large flat surface. An extra layer couldn't hurt, but probably isn't necessary. The biggest benefit may be in noise transfer reduction tho and that alone would make it worth it to me.
wwhitney
Berkeley, CA
If it's an isolated copper manifold for PEX (not specified in the OP, but common), I would think it wouldn't be moving much (not much length for thermal expansion).
Cheers, Wayne
WorldPeace
Great idea. They sell Teflon pipe that should work. I'll just cut and glue a small ring to the clamp.
WorldPeace
Thanks for the advice. I guess I'll just add some Teflon cushion to minimize any noise. It doesn't cost much and doesn't require that much more work. Thanks!
