Russell Brown
Hi, I recently had a new irrigation well dug as the old one collapsed. The well was dug to 60' with 2" PVC. I did the plumbing hookup my self. The well guy said to put the check valve close to the well pipe, so I put it right after the 90 degree elbow. I then ran 2" PVC to where the old 1 1/2" PVC came from the pump. I used a 2" to 1 1/2" coupling. I primed the pump and the well worked great. There is about 60-70 feet from the pump to the well.
However, after a day, the pump loses it's prime and I have to re-prime it. On the old 1 1/2" plumbing the check valve was close to the pump. I have no idea if there was another valve close to the well as we could not find where the old well was.
My question is ... should the check valve be closer to the pump? Is that why I keep losing prime? If so, can I just add another one, or should I take the one by the well off?
Also, I dug up my piping to check for leaks and I can't find any ....
Any help or suggestions would be great ...
Thanks in advance!!!
