cartim
I have a larger lot and the furthest zone (all zones are designed at 25gpm), which is about 400 feet away from the meter. The pump will be about 125 feet away from the meter. From the meter there is only 2 feet of height difference to the last zone. (400 feet away) There is about 14 GPM at around 55 psi available from the 1 inch meter.
What size pump discharge and mainline sizing should I install leading to that farthest sprinkler zone?
What is the correct size of pump that I should I install to deliver 25 gpm to all the zones especially the ones furthest away?
There are also low volume drip zones and a couple of sprinkler zones that have much lower gpm requirements. Do I need any reducer valves for this or will the pump control cut off for these lower volume zones?
Thank You for you time!
