Irrigation line dripping.......
suttonjosh
Minnesota
Hi all,
I have a main shut off for my irrigation (yellow circle on image) and there is a spigot (red circle on image) a bit up from there to make sure all the water gets out when winterizing.
It continuously drips (very intermittent, but always water in the bucket). If I leave the spigot closed it builds up. I had a backflow cap on it, and removed it to see if it would still drip if off, not sure why but just removing all variables.
It is now day 2 of having the backflow off and there is still a drip. This is the first year we have had this issue.
I curious if this may be indication of a bad ball valve at the main shutoff for this line?
All thoughts, suggestions and feedback are appreciated!
Thanks.
In that system, if ANY water, (rain, dew, etc.), enters the system from the lawn area, it WILL drain into your bucket. I t appears that your system does NOT have the REQUIRED vacuum breaker/backflow device outside 12" above the ground level. IF it does have the VB/BFP valve then the ball valve is leaking and has to be replaced.
