Hi all,
I just went on a walkthrough of a house on the market and looked in the utility room. The home has a traditional well system with a Large pressure tank and was at a pressure of 76 PSI. I’m assuming it’s a 60/80 pressure switch. The home also has a built in irrigation system that uses about 20 gpa of water with each zone having 6 heads. I don’t know the exact specs of the well system, but it had an in line booster pump for the irrigation. After doing some research, I can’t figure out what this is for. Why would this be needed. The house I’m currently in has a constant pressure well system that holds 70 psi with a very similar irrigation setup with the same sized/layout of yard, but we don’t need a booster.
