Bannerman
The backwash rate is determined by the tank diameter and water temperature, not the quantity of media the tank contains. IOWs, removing 50% of the media in the exsisting tank will not provide a more thorough backwash of the remaining media.The seller suggested to scoop out 1/2 or even 1 cf of the media, which is questionable due to the recommended by the manufacturer media depth.
If the backwash rate is insufficient due to your well pump flow rate, a smaller diameter tank will better utilize the pump's flow rate for back Washing. Because a smaller diameter tank will typically contain less media, to satisfy your home's flow rate requirements, 2 independent back Washing filters plumbed in parallel maybe required. Each filter would then backwash independently on an alternate schedule from the other.
You have mentioned 4-5 ppm ferrous iron passing through the KL media, but I do not recall the iron amount pre treatment. Post your most recent lab test report so all water conditions can then be reviewed and considered,
