JSAlaska
I've searched the forums here but some of the answers to my questions seem to be more technical than I can interpret. I have two questions regarding my Fleck 5600 sxt 32k Iron Pro water softener. We have had the unit for a little over a year and are generally happy with it. Two questions are:
1) We had problems with iron, manganese, and iron bacteria that showed up after an earthquake. We use Morton Rust Defense or similar salts which took care of the post-earthquake iron bacteria problem. My question is, should I also be using Iron Out or a similar product once a year to help clean the resin or is the Morton Rust Defense salt enough?
2) I have no idea how to determine how much salt we should be using. Since installation, we've been using the pre-set manufacturer regeneration cycle and salt settings. It seems like we're using a lot of salt though I haven't kept track all that well. How much salt should I be using or how do I determine how much salt I should be using?
The water test results below are from a reputable lab and are the results from BEFORE we installed the Iron Pro.
Water testing results
Total Hardness -- 9.9 GPG
Calcium -- 52 ppm
Iron -- .47 ppm
Manganese -- .49 ppm
Magnesium -- 8.7 ppm
Langlier Index -- .11
Alkalinity -- 97 mg/L
pH -- 7.84
Total Dissolved Solids -- 221 mg/
Thank you very much for any thoughts or advice.
Calcium -- 52 ppm
Iron -- .47 ppm
pH -- 7.84
