68malibu383
Thought I'd share this as it may help someone diagnose the same problem in the future. My 10-year old American Std toilet would flush as normal at times but other times, it would start to flush properly, then water would just back up in the bowl. Happened with solids and liquids.
Once when flushing, I thought I saw a small red thing at the edge of the "jet" if you will, in the bowl. When the water stopped swirling, I did not see it. I wondered what the red thing could be and then I realized it was one of the two discs that holds the float onto the chain in the tank.
One day, I was able to see a small edge of the disc after flushing. Stuck my finger in the jet to tried to grab it, but the disc retreated into the hole. Tried to grab it with pliers, but it disappeared again. I only see the disc about every 10-15 flushes and don't think I'll be able to grab it. So, I'll drain the toilet and try to suck it out with my shop vac from inside of the tank at the flush valve.
Wonder how often this happens?
