We planned to install a Geberit DuoFix in-wall system for 2x6 wall, but are considering using the one for 2x4 wall to allow for more space behind the unit for more insulation. This is going on an exterior wall, which is why we are concerned about insulation. The exterior walls have been gutted and we plan to insulate the exterior wall cavity and build out another wall cavity for the Geberit frame. Another thing that adds concern is the cast iron vent/drain stack in the corner!
So, my first question is, in addition to insulation in the exterior wall cavity, what additional layers of insulation should we add to give us reasonable comfort that the tank will never freeze (we live in central Ohio). And is spray foam insulation sufficient around the vent stack (see the picture)?
Second question, does it make sense to use the 2x4 unit instead of the 2x6 unit to allow more space for insulation without having to move out the finished wall?
Third question, are there any advantages of the 2x4 or 2x6 functionally? is one easier to maintain/repair?
Thanks for any assistance in making this work!
