My floor slopes where I'd have to shim the toilet 3/8". This will be my first Toto and we’re thinking of getting the Nexus…installation appears to be strait forward. My questions are: Can I install the UNIFIT Rough In flushed to the floor then install the shimmed toilet over that or do I have to level/shim the UNIFIT Rough In as well? I called Toto tech department and they’re aren’t that technical but they said when the toilet is placed in position on the floor over the UNIFIT, 2†of the toilet’s Spigot Outlet goes into the UNIFIT’s rubber sleeve, so I thought there may be room to shim the toilet? Does anyone know?
I don’t know if the Nexus has a thick enough bottom lip to shim or if I should do something else? I even asked Toto would it be easier if I got a different toilet instead. This is the Charm part of older homes…
