clawbennett
Okay, newbie question here. We are redoing the shower, and I have probably a very basic question.
We are installing a shower enclosure and before I permanently attach the enclosure wall on the shower valve/faucet side, I want to ensure there are no leaks in the plumbing and the valve. The copper soldering looks kind of nasty and I am not 100% confident there are no leaks.
It's a delta valve, and during the initial water pressure test it worked fine with no leaks. However, I believe that when they tested the valve they started with the cold water side. They did NOT use the test plug, and I am assuming cold water may have gone down the hot water side before they opened the hot water valves. The water valves are in the basement away from the shower fixture. The Detlta valve test cap got damaged during the work somehow. To relieve the pressure they unscrewed the bonnet that held the test cap in place and it exploded with pressurized water. I am not sure that's how you're supposed to relieve the pressure.
So, my question is can I install the faucet cartridge and check for leaks before installing the wall permanently? Also, would the best way to relieve the water pressure after a test be to unscrew the plug from the shower drop elbow instead??
