Installing Moen Flo - Question about Bonding Wire and Soldering
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by cai24, Jun 26, 2021.
  1. cai24
    cai24 New Member
    Mar 24, 2018
    New Jersey
    I am planning to install a Moen Flo, which turns the water off in the event a leak is detected. I’m not sure how I address the bonding wire. It runs to right above the existing gate valve. Do I need to terminate the bonding wire above the Moen Flo and then somehow splice it to run it underneath? It seems like it would be easier to just run it right around the Flo, but I don’t know if that’s acceptable (or if I even have enough length).
    My basement walls have foil/bubble wrap insulation. Is it safe to solder against this, or should I buy a heat shield?
  2. kreemoweet
    kreemoweet In the Trades
    Sep 7, 2009
    Seattle. WA
    Ask Moen whether the thing is metallic/conductive, that info is not apparent from Moen's descriptions. If so, there would be no need to alter your electrical connection,
    except that if it is not just a bond, but part of the grounding electrode system, it would need to be within 5 feet of where it enters the building.
    Bubble wrap contains meltable plastic, and should be shielded from soldering heat.
Similar Threads: Installing Moen
Plumbing Forum, Professional & DIY Advice Installing a new Moen post valve Feb 9, 2020
Plumbing Forum, Professional & DIY Advice Installing Moen A725 series Drop Ell Nov 8, 2019
Plumbing Forum, Professional & DIY Advice Replacing/Installing Moen Renzo kitchen faucet Feb 2, 2019
Plumbing Forum, Professional & DIY Advice Problems installing Moen shower valve. Jul 11, 2010
Plumbing Forum, Professional & DIY Advice Installing a moen faucet: PVC gasket vs silicon Nov 9, 2008
