Need some help.
Purchased a Fleck 5600SE water softener.
The guy I purchased it from delivered it and was to return the following weekend to install.
That was months ago.
I decided to tackle the job myself.
Plumbing went fine. Softener installed. No leaks.
Problem is programming. My old one had a chart for hardness, people and how often it should run.
I don't know the capacity of this unit. No documentation with it when I unboxed it.
Resin tank is 55" tall. 52" to where the tank curves to the neck. 10" diameter.
Resin comes up to 41" in tank.
Water hardness is 24 grain? untreated.
This unit is supposed to monitor usage and regenerate when # of gallons is used. Correct?
How do I determine number of gallons? What else do I need to program?
Thanks in advance.
Bob
Thanks in advance.
Bob
