Hello, I was refereed to your forum from TOH forums... My question is:
I will be installing a front loading washing machine about 6 to 7 feet away from the drain. The manufacturer says the unit will pump 96 inches vertically. My install will require about 66 inches. so about 66 inches above washer I will install the drain which needs to travel 6/7 feet to the wall where i can install a trap and connect to the drain line for the home.
1.Is 2" drain pipe the correct size
2. what is the pitch i need in the drain line
3. should i install a check valve at the washer output
4. I was thinking of hard plumbing the washer output to the drain,(no air will be able to enter the line) and installing a sure -vent air admittance valve in the pitched run as soon as I have the clearance to do so.
Does any of this make sense.... I would appreciate any suggestions you have....
