Ralph Vart
Hello Members,
I need to install a union between an existing elbow and a T on a 3/4 inch residential gas line. I'm not sure it can be done, but thought I would ask for your advice.
The photo I pasted below shows the set up. I want to install a union on the horizontal 5" nipple painted tan that runs between the 90 degree elbow and the T. I'll explain why later, but I need to disassemble the fittings all the way to the 1.25" vertical pipe painted grey (the one with the valve on it).
I don't think I can take apart any of these pipes, since they are locked in place. Somewhere along the line, plumbers decided to add stuff without putting in a union. My idea is to cut the 5" nipple and put the union between two smaller nipples, probably a 2" and a 2.5"
I foresee two problems. The two nipples and union are going to need some play to fit together, but there isn't any. (if you are thinking there is some way to disconnect the pipe traveling to the right, there isn't. It hits an elbow and goes through the wall.) How do I deal with that? And it looks like nipples come in only half inch increments, so what happens (even if I can get them all threaded) if I need less or more than that? Can they be custom made? Can I get a chisel and knock away from stucco and get a half inch of play that would allow me to get the union in place?
As for the reason I am doing this, that vertical 1.25" pipe is a long gas line to a pool heater. It was leaking underground and replaced in two areas. That was great. It held pressure. But the plumbers never blew the lines clean. As a result, the heater was not getting enough gas to ignite. I was able to clear a blockage right at the valve going into the heater and it did ignite. But I am sure there is more debris in the pipe that could clog up again or worse clog the gas valve on the heater. So, my idea is to disassemble the ends of the pipe near the meter and near the heater and blow the lines with compressed air. Yes, the plumber who did the repair to the pipes should have done this, but he's out of the picture now.
