1BadF350
DIY Junior Member
When we had our house built, I had the plumbing company install a recirculating line and stub it out the wall and put a ball valve on it so it could be closed off. Today I went and bought the grundfos pump along with 2 check vales..
The cold water supply line going into the water heater is 3/4" and the hot water line coming out of the heater is also a 3/4" both lines have threaded ball valves and then the stainless steel braided lines feed the water heater..
The very last faucet is the bath room in my daughters room, and under the house at that point the hot water line goes from 3/4" and is reduced down to 1/2" and then runs all the way back to the garage and stubs out the wall about 16" away from the other hot water lines.
Could someone be kind enough to tell me how to install this pump? I would would prefer not to install it through the drain valve of the water heater unless there is a benifical reason..
I am very good at sweating copper joints, so that is not an issue for me, just want to make sure place in correct location and get the check valves in the correct locations also...
1 other question, should I install one of the pressure tanks? or city code does not require on, but if its benifical, I would rather do it now, versus later.
Thank you for all you help in advance.
Chuck
Chuck
