handy at many things
Hello, 1st time here.
Have item above to install with no physical way to burrow or access below slab into original cut out for tub. Apt. Bldg. mid-60's vintage in San Jose, CA. Plan A is wanting to find a doable way to drop tub in place, much like what can be done with shower bases/pans. Already bought tub and have ample experience with this model on upper floors with access from below. But this is on slab. Lot's of hands on experience/knowledge, but not how to manage to get this done. Don't want to waste anyone's time so will say my plan B necessitates purchase of different style tub that doesn't have integral overflow to reproduce, but rather has typical overflow and shoe assembly, similar to what had been in place for 50 years+. My only thought here, as impractical as I know it will be and still hard and questionable as to ability to do so, is to jackhammer out 4" slab to extent that I could possibly reach in through exterior access panel from outside building on ground level parking/driving surface, and still logistically its a stretch unless I was tiny enough to crawl in (have to be 2 feet tall and strong) or had v. long arms. Not saying it might not be doable, sayin hell I don't want to go that route.
Anyone experienced with setting down this specific tub from above only, and properly setting into place and sealing (blindly) as needed. I'm looking to use 1.5" abs from cast fitting out thru p-trap and up to somehow transition to tub drain for Plan A. I understand practical reason why tub drains don't get installed like the shower drains.. cause they're only 1.5" dia so rubber bushing concept won't fly here, unlike 2" shower base drains. Still, maybe there is a standard tub designed/built with 2" drain, as that would be doable solution if available and within $3-500 price window.
Lastly, an earlier post dated June 2, 2018 entitled: Installation of American Standard Princeton Bathtub w/Integral overflow, was clearly not understood by those few that contributed to that post and/or williamk who initiated that thread misidentified his tub. Thanks in advance for any guidance.
Where's HJ.. perhaps engaged in manufacturing my standard size and priced tub with 2" drain. White please. Quality conscious too!
