Good afternoon,
I am currently designing a whole home filtration system to supply water from a freshly dug well to my home. I’m looking for input and advice on what I have come up with so far, and was pointed to this sub forum for the system critiques.
My other thread regarding which pump setup to use to boost the pressure from the atmospheric tank to the home can be found here:
https://terrylove.com/forums/index....ble-setup-for-whole-house-booster-pump.83250/
The well specs are as follows:
A brand new 2” well has been dug to 65’. PH 7, Hardness 31, iron 0.4, sulphur 5+, slight tannin, TDS 599. The driller’s 1hp temp pump was pumping 23 gpm.
From there the plan is:
220v Gould j15s (with psidekick?) at well, 5-6’ above water table, pushing 150’ to home
Sediment filter
1.5 cube water softener
2000-4000 gpd reverse osmosis
~500 gallon atmospheric holding tank
Ozone in tank
Repressurization pump with psidekick
2 cube Calcite filter (highest gpm possible)
2 cube carbon backwashing filter (same)
UV filter
Line in to the home
The list above is in tentative order. Would you change it? This is my current plan, please let me know if you see anything that needs to be changed.
The pump sits about 5-6’ above the water table, next to the well, and will push water about 150’ to the filtration system (I will also be adding a tee for irrigation.)
The water will pass through a sediment filter, then water softener before going through the RO filter, which requires ~12gpm flow, and has between 50-75% efficiency.
From there the water depressurizes as it enters the atmospheric tank which will have an ozone bubbler to help the carbon filter with the sulphur.
At this point, I’m either going to do a submersible or standard booster pump which will repressurize the system to go through the calcite and carbon filters, and finally the UV filter and into the home.
The RO will be controlled by a float switch system, and the well pump will be on demand.
The well side *should* only run a few hours a day and in one or two cycles as it refills the storage tank, and also when the softener needs to be washed or irrigation use.
The house side will run whenever we need water, so it will cycle pretty often, and that’s where I currently am.
Does that setup make sense? Would you rearrange/change anything? This is probably the 4th or 5th time I’ve redesigned it, with input from my neighbor (25 acre hydroponics farm with full RO system), and three different water system companies.
Sediment filter
Ozone in tank
UV filter
Line in to the home
