Ingredients of Cements and Primers
Flapper
California
FYI, here are the ingredients of the more common Oatey primers and cements.
Oatey Regular Clear PVC Cement: Tetrahydrofuran, Acetone, PVC Resin, Cyclohexanone, Methyl ethyl ketone
Oatey Medium Clear PVC Cement: Tetrahydrofuran, Acetone, Methyl ethyl ketone, PVC Resin, Cyclohexanone, Fumed Silica
Oatey Heavy Duty Clear PVC Cement: Tetrahydrofuran, 2-Propanone, Cyclohexanone, PVC Resin, Methyl ethyl ketone, Colloidal silicon dioxide
Oatey Rain-R-Shine PVC Cement: Tetrahydrofuran, PVC Resin, Acetone, Cyclohexanone, Methyl ethyl ketone, Fumed amorphous silica
Oatey All Weather PVC Cement: Tetrahydrofuran, Acetone, PVC Resin, Cyclohexanone, Fumed amorphous silica
Oatey Blue Lava Hot PVC Cement: Tetrahydrofuran, Acetone, PVC Resin, Methyl ethyl ketone, Fumed amorphous silica
Oatey All Purpose Cement: Tetrahydrofuran, Acetone, Cyclohexanone, Methyl ethyl ktone, PVC Resin, Chlorinated chloro-homopolymer ethene, Fumed amorphous silica
Oatey ABS to PVC Transition Cement: Tetrahydrofuran, Acetone, Methyl ethyl ketone, PVC Resin, Cyclohexanone, Fumed amorphous silica
Oatey Medium Orange CPVC Cement: Tetrahydrofuran, Methyl ethyl ketone, chlorinated homopolymer chloro-Ethene, Acetone, Cyclohexanone, Fumed amorphous silica
Oatey Heavy Duty Orange CPVC Cement: Tetrahydrofuran, Chlorinated homopolymer chloro-Ethene, Acetone, Cyclohexanone, Fumed amorphous silica
Oatey Medium Black ABS Cement: Methyl ethyl ketone, ABS Resin, Acetone
Oatey Purple Primer: Acetone, Cyclohexanone, Tetrahydrofuran, Methyl ethyl ketone
Oatey Clear Cleaner: Acetone, Cyclohexanone
Oatey Purple Primer/Cleaner: Acetone, Cyclohexanone
Tell me if you want to add a product to this list to compare.
Things of interest:
  1. Regular Cement has the same ingredients as Primer, but it also has PVC resin in it. Theoretically, if you have an old can of PVC cement that is getting thick or is jelly-like, you can add primer to it to rejuvenate it.
  2. Primer has the same ingredients as Cleaner, but it has two more ingredients. This tells us the difference between Primer and Cleaner, and obviously it is NOT the same.
  3. Primer/Cleaner has the same two ingredients as Cleaner, but not the two extra ingredients as Primer. If it can be used as a primer, then does that mean cleaner can be used as a primer?
Nice list of the ingredients listed on the cans, but your point is? I am sure that the "proportions" of materials is germaine to their relative usages.
Point is, it's interesting.
It tells you the differences between the types of cement if you're wondering what the differences are.
People can find this when searching on Google.
