FixingThings
Hello,
I have this 24yrs old Delta 600 series shower set that has a slow leak through the spigot.
I already bought the rubber and spring valve parts that should fix the leak, but I have had quite a bit of trouble trying to remove the dome that houses the valve. I have tried PB blaster overnight, Wd40 and I am using a pipe wrench and then tapping the wrench with another wrench to try to unscrew it as seen on some videos who had success.
I stopped because I chickened out really since I don't want to bend the 3 copper pipes that feed the valve, but it seems that I managed to move it a bit. Before I continue tapping at it I wanted to ask you guys if you see this method as too risky for the condition of this valve as shown here on the pics. I don't want to mess it up and break the pipes and then have a super expensive repair, but It seems that I got it started.
Would you rather cut the dome open with a dremel tool and a circular saw? then put a new one?
Also, there seems to be a lot of green on the pipes indicating there was a leak at some point, but I could not find any moisture or water or any indication that there is a leak now. I used a paper towel to touch around the valve and look for moisture and nothing.
I do see that the bottom behind the shower has some black on the wood floor, but could that be from an old leak. I don't see any moisture where the long pipes meet the joists. Shouldn't that area be wet or rotted or show sings of water sliding through the pipes there if there was a leak that persisted?
Lastly, when I unscrewed the front Delta round plate, I heard that something dropped. It seems that there was a 2x4 wedged in between the front of the valve and the back of the plate? Should I attempt to put another 2x4 back and where would it go? On top of the valve I assume?
Here are some pics (smaller in size this time)
Thanks
Thanks
