Hi all,
Submersible pump in a 150' well with an indoor check valve right at the inlet to the pressure tank. Historically, this check valve has BANGED (makes a popping sound) when the pump started, but it always did it intermittently. I'd go for months without hearing it, then it would do it consistently for a couple of months, then stop again.
Pump was replaced about 4 months ago. The BANG stopped. It has since returned over the last couple of weeks. Maybe it's correlated with the winter weather, or maybe it's a coincidence.
I've read a lot on here that if the check valve at the pump in the well doesn't seal, that a vacuum can be created on the indoor check valve, and when the pump is started, the indoor check valve releasing is the source of the noise.
Can the check valve on the new pump be bad already?
Other than the noise being a little disturbing, the situation does appear to be contributing to the pressure relief valve dripping ever so slightly. I have plastic piping in the house, so I'm not a fan of a continued hammer situation.
I did confirm that the pressure tank bladder is intact and the pressure on the air side is holding just fine.
Thanks in advance for any help!
