Gsmith22
Active Member
Posting this here rather than the softener forum because I think I will get better "plumbing" responses as that is what this question(s) is really about.
Have a water softener (cation exchange) tank, anion exchange tank, and carbon tank as part of my well water treatment that all have drain lines for backwashing/regeneration. The tanks are all located in my basement but all plumbing drainage pipes are overhead (basement is unfinished, no floor drains, sinks, showers, etc. in basement). I had been making due with a makeshift drain system from a prior owner softener rig job (hose routed through floor to laundry tub/dont' get me started on this guy's various rigged systems) that I want to correct and be properly done per code (which is 2018 NSPC in NJ). I intend to install a 2" standpipe with trap and AAV to vent the trap attached to one of the overhead drain lines in the basement. This new standpipe will be positioned so that the standpipe opening is up near the underside of the first floor - see last post #14 in this thread for exactly what I intend to do: https://terrylove.com/forums/index....ner-to-overhead-sewer-line.80481/#post-582297
The issue that I am trying to figure out is that my water line comes into the house at the opposite end of my basement than the main drain line exiting to the septic system. So where the tanks are all located, the overhead drains are all up too high to incorporate the standpipe. The standpipe can't be installed closer than ~60ft from the tanks. This means that the indirect piping from the water treatment tanks is going to be ~60ft as well.
1. I keep reading that indirect piping can't be over 15ft long (although I can't find that direct restriction in the NSPC Chapter 9 http://epubs.iapmo.org/NSPC/NJ2018/mobile/index.html#p=130). Can anyone point to this being the case? My HVAC condensate lines are definitely more than 15ft and that was approved by plumbing inspections.
2. I have also read that the indirect piping has to have a trap when 10 or longer but for the life of me I can't see what that does since this pipe would not connect to the drainage system (it will have an air gap at standpipe). There is an exception to clear water wastes (which I think is what comes out of these water tanks).
3. Finally, do you think I need to run three separate drain lines from the tanks to the standpipe or could I combine the lines into a single drainage pipe and run one line from the tanks over to the standpipe? The tanks don't backwash at the same time so the indirect line could be sized for one tank backwashing but I wasn't sure about some issue with the drainage from one tank commingling with the drainage from another. When one tank runs, it pressurizes the line (via the house water pressure) and essentially would pressurize the drain line of non back washing tanks when one of them is back washing (since they would be connected into a common manifold)
Hoping someone has done this and I am not reinventing the wheel
