Lisa D. Lucas
When remodeling/adding on to my house I installed a tankless water in the newest side, which happens to be farthest from the water pump/inlet. I kept the original side of the house on the standard 52 gal. electric heater until it failed. At that point, I connected the original plumbing to the tankless heater. Works just fine, except there is an extremely long run for the water before it gets to my kitchen. I am wasting obscene amounts of water just waiting for it to get hot. I envision adding a thermostatically controlled point of use heater at the sink that will turn on and heat the incoming water and then shut off when the water that has been heated by the tankless unit finally gets down the line. Trouble is, I haven't found such a device. Trying to find a cheap, simple solution without involving a recirculating system and tank. Anybody know of such a device? There are numerous point of use heaters, but I'm looking for one that sense the temperature of water coming into the unit and shut itself off.
