Hey folks. Awesome resource here. Been sucking up info as I remodel my bathroom, but apparently not quite enough info.
I plumbed our new tub last night. Moen valve with Pex to hot/cold and shower, and copper to spout. Got everything done and realized I hadn't sweated the copper for the spout. It was crazy late and I'm running on empty from living in this bathroom day and night, so I stupidly decided just work quickly to get the down pipe soldered on. The valve body got pretty hot, as did the crimp rings closest to the valve body, but I don't see any melting or deformation of the teflon tape nor the Pex. The hot/cold are holding pressure, but now I'm really worried about the long-term reliability of the system. I'm also not in love with my solder joint as it didn't seem like the solder was getting sucked up into the fitting.
Couple other details. The icing on this stress cake is that I still need to solder the elbow to the spout pipe. It's a 10" line. I was initially going to wrap everything with a wet towel, but am second guessing that. I'd also like to pressure test my copper, but doing so means soldering a cap on, taking it off, then soldering a threaded fitting on for the spout. I know that line isn't typically under pressure, but like I said, I'm not in love with the joint. I'd appreciate any advice or thoughts.
