One thing to consider although the ground temperature changes season to season, and not all that much on a day to day basis, all of the plastic pipes will expand and contract MUCH more than say a cast iron line. This can put some radical stresses on the pipes if they aren't installed with that in mind. Yes, CI has a thermal coefficient of expansion, too, but it's a LOT smaller than most of the plastics out there.
In the row of condos I live in, owners added condensing furnaces and did not install acid neutralizers. The in-unit drains are PVC, which can handle that well, but the main line between units that also exits the row of buildings is cast iron. The CI is starting to need replacement from the acid running down the lines. In the process, we're looking at if we could do this in PVC (preferred for costs) versus CI, but in the longest straight run, with inlets from units along the way, I calculated that the length could change 3" from winter/summer and as people are doing loads of laundry or taking showers...that would literally shear off some of the connections and cause the pipe to warp, potentially creating a dip, too, that could cause a blockage. My recommendation is to add acid neutralizers, and keep the CI run the same...we might go with hubless, as it's easier to find people with that skill to install than hubs and lead, but who knows...this will become an issue for us in the next year or so that will no longer be able to be ignored.
SO, just another thing to keep in mind when selecting a material and getting it installed so it should last without issues.
