Hi. I am in the process of replacing the wax ring on my toilet this morning. When I turned off the water and then disconnected the inlet hose from the toilet I noticed on the ground a small washer and a large rubber auger-shaped piece. I had turned my head so I can't be 100% sure they came out of the fill valve when I disconnected the hose but nowhere else makes any sense. Can you tell me where they go and how to put back or if the fact that they are out means something is actually broken and needs to be replaced. I have attached pictures of the inside of the tank to see my setup, the rubber piece and washer, and a picture looking up into the pipe of the fill valve assembly. Thank you!
